Rubbing
Old Jun 25, 2008 | 11:34 AM
99and04f150's Avatar
Rubbing
I am getting ready to do my lift kit and tires. I got the Auto Spring 2.5" front lift kit, I want to put on 315 70 R17 (stock wheels). Any of you guys doing that and if so you all rubbing at all or anything I should be aware of such as braking issues. I am going to get the Edge Evo. Prgm. to recalibrate everything so I'm good there. Any tips or advice would be great!
Thanks,
Dave
Old Jun 25, 2008 | 01:09 PM
Thanks,
Dave
On the stock wheels you may get a little rubbing on the upper control arms making a full crank, nothing major. I have my 315's on 8" wheels with 5.5 inches of BS, about as close to stock as you can get. I have no rubbing at all. I set my edge on lvl 2 and adjusted for tire height in milimeters and this also adjusts your speedo. I've been getting up to 18mpg hwy and am quite satisfied. All this info is assuming you have a 4x4 truck. Also I put on carquest blue pads on to help with braking. Hope this info helps.
Old Jun 25, 2008 | 01:27 PM
wandell's Avatar
I agree.
Old Jun 25, 2008 | 04:32 PM
thanks alot guys greatly appreciated and yes my truck is 4x4. cant wait to get this all hooked up
Old Jun 25, 2008 | 10:37 PM
4wheel parts is having a sick sale on tires
Old Jun 26, 2008 | 06:23 AM
Deer_Predator's Avatar
And if I am not mistaken the 315 70 17 is approximately the same as 35x12.50x17's correct?
I am wanting to go from the 33's to 35's on my 97. Just double checking before I take the plunge....
Old Jun 26, 2008 | 06:25 AM
Sorry...I am toying with my signature.......Let's try this again....
Old Jun 26, 2008 | 11:56 AM
Fish Chris's Avatar
Hey Deer_Predator....
and if you haven't seem them, Paw Paw's 315/70-17"s look fantastic !
To answer your question though, 315/70-17"s are listed on the BFG website, as having a 34.5" diameter.
Hey Paw Paw, BFG also says the minimum wheel width for this tire is 8.5 inches, but your running them on 8"s ? No problems, huh ? I wonder if this helps to make your wheels look even fatter (better :-) by bulging out a little farther from the wheels ?
Fish
Old Jun 26, 2008 | 12:04 PM
Fish
Thanks Fish....With the Pro Comp's they reccommend an 8" wide rim for both the 33's and 35's....I am running the stock 7.5" with the 33's....and no problems.
Old Jun 26, 2008 | 12:45 PM
wandell's Avatar
Yes, a 315/70-17 is essentially a 35x12.50-17.
Old Jun 26, 2008 | 01:06 PM
Fish, no uneven wear running these tires on 8" wheels. I've got close to 25k miles on them and they still look new. Also Deer Predator, I don't know if you have a body lift or plan a suspension lift because I think on a '97 you will need one to clear 35's. Check with Wandell on this.
Old Jun 26, 2008 | 02:23 PM
I do not have a lift on either body or suspension. However as you can see from my pic I do have sufficient clearance with the 33's that are currently on the truck.....
Hopefully Wandell will be able to decipher whether or not I will need them.....Thanks for the heads up though Paw Paw.
Old Jun 26, 2008 | 08:35 PM
wandell's Avatar
THey will fit if you use your oem wheels. However, they are gonna rub the frame at full steering lock. If you are never gonna lift the truck, I'd stick with some 33's.
Old Jun 26, 2008 | 09:34 PM
Thanks Wandell, PawPaw, Fish......I will take all into consideration. Too bad I can't find anyone who will do a "test fit" with some 35's...
