Time to replace my orginal 2001 tires, suggestions?
Old Jun 24, 2008 | 11:28 PM
wglong's Avatar
I have a 2001 4x4 extended cab flareside. My original Goodyear's are about done (only have 45k on the truck). I don't want to add any lift or level to the truck and have two questions...
1) If I stay with my stock rims, 17" (265/70-17) what is the max tire size I could put on them?
2) If I upgrade the rims to 18", what is the max tire size I could put on those new rims?
I really don't want to mess with the suspension, I'm just trying to get a beefier tire (and new rims if the budget allows)
Thanks!
Old Jun 25, 2008 | 12:50 AM
4.2trimble's Avatar
Well you can clear 285/70/17's without doing anything!
Now Im gonna ask, why dont you wanna level the truck? Its a simple task just cranking the stock torsion bars to level the truck then you can run some 305/65/17's
Old Jun 25, 2008 | 01:20 PM
wandell's Avatar
I agree. As for tires, if you have the Wrangler RT/S, just about anything will be an improvement. I'd look at the BFG AT KO's, Nitto Terra Grapplers and Toyo AT's.
Old Jun 25, 2008 | 08:14 PM
wglong's Avatar
Well, I guess I could level the truck. Am I correct in all it does is bring up the from part of the truck with the back? How much is this usually and can it be done via DIY?
Old Jun 25, 2008 | 08:34 PM
wandell's Avatar
It's free, basically. Locate the torsion bars and follow them from your lower a-arms back underneath the cab. There is an adjustment bolt and cam at the end of each one. You just turn each torsion bar preload adjustment bolt up an equal number of turns untill you reach the height you want. Then get the front end aligned.
Old Jun 26, 2008 | 01:50 AM
4.2trimble's Avatar
Yeap you can jack the frontend off the ground to make it easier but when i went up to 36's i just sprayed the bolts with PB Blaster for a day or two then cranked them without jackin up the front.
Nothing to it really!
