33x13.50 wheels?
33x13.50 wheels?
I mean Tires...This might be a stupid question, but what does this translate to as far as what size rim can be used?
I'm only used to the 285/65/20 type descriptions.
you should be just fine with a rim from 8-10 inches in width. just keep in mind that is a wide tire.... so i would get as wide as you could fit on the vehicle with the backspacing. the narrower the rim, the more it will push the tread out.
It will depend on the wheel. I'd recommend a 9 inch wide wheel with 5 to 6 inches of backspacing.
