Tire/Wheel combo on 02 Screw
Old May 5, 2008 | 04:43 PM
mudd1's Avatar
Want to put 305/65/17 BFG A/T's on 17x9 with 4.75 BS on my stock 02 Screw. The torsion bars are cranked halfway to level the truck, other than that its stock. Anyone see any rubbing issues at full lock? Or any other rubbing issues?
Old May 5, 2008 | 04:53 PM
4.2trimble's Avatar
I dont see much rubbing but there might be alittle. Someone else will be coming along soon that could tell you for sure. It all has to do with the wheel offset and backspacing im not the best with that.
It should be fine and if it rubs at full lock just avoid turning to full lock it actually easy... i never turn to full lock
That tire is a 32.6 x 12 tire. You will be fine! i highly doubt it will rub!
Old May 5, 2008 | 08:25 PM
wandell's Avatar
You will probably have to trim a little plastic off the front bumper's lower valance. I have pics in my gallary.
Old May 7, 2008 | 03:43 PM
mudd1's Avatar
Not a problem. Just want to make sure with the width of the wheel and back spacing, i wont be rubbing the frame or anything else besides possibly the valance.
