bad rotors causing constant vibration?
i have a 98 f150 SC 4X4... i have had a slight vibration for quite some time but seems to becoming more noticeable... in the floorboard/pedals/steering wheel... basically everywhere... at certain speeds it is worse than others... mostly felt while keeping a steady speed around 50Km and also at about 110Km... it is also amplified when i press the brakes which leads me to believe it is a warped rotor... i have heard that a bad enough rotor will "bump" the pads causing a small constant vibration that is worse when brakes are applied... can this be possible?... if a rotor was that bad wouldn't it cause my truck to pull to one side?... it goes perfectly straight down the highway for a long ways.
also, perhaps unrelated... O/D light began flashing after 80Km/hr... had it checked and code states that it is the VSS... my speedometer does not seem to be correct because of this.
