Electric Brakes
Sounds like you purchased your truck used, so the relays that came in the accessory bag might have already been installed in the underhood relay box (if it came with the factory tow package).
If the wiring plug under the rear bumper near the hitch receiver is a seven-pin connector, then you should be wired for electric trailer brakes. If the plug is a flat four-pin, then you are not wired for trailer brakes. In that case you probably don't have the factory tow package. Your hitch and wiring were probably added after the truck was originally purchased.
If you have the factory tow package, the previously mentioned accessory bag should also have contained a seven-pin to four-pin adaptor, for use if you want to tow small trailers with only a four-pin connector and no brakes.
