Professional Help Needed
Old Apr 19, 2008 | 02:48 PM
BigRed91's Avatar
Exclamation Professional Help Needed
Hey guys, just got my bigger tires put on yesterday and looks great but I noticed that the fuel gage goes down a lot quicker than normal. I know that by getting bigger tires that I am going to loose MPG but i was curious to see if anyone knows how to improve it. New Exhaust? need help please
Old Apr 19, 2008 | 02:54 PM
4.2trimble's Avatar
First what size tires did you get?
Second The distance it says on your trip is slightly off because the tires have a bigger diameter thus not turning as many times in a mile.
Third The gas can be improved with Tuners, Intakes, Exhaust, and most importantly GEARS.
Tell use the tire size first though!
Old Apr 19, 2008 | 04:51 PM
BigRed91's Avatar
they are toyo open country 295-70-17 on a 2004 scap 5.4 L
Old Apr 19, 2008 | 04:59 PM
4.2trimble's Avatar
Ok well id do the simple bolt-ons first
1. Headers
2. Exhaust
3. Intake
4. Programmer (xcal 3)
Now the biggest bang for the $$$ would be
1. Gears 4.10-4.30
SIDE NOTE: If you plan on getting a lift and bigger tires in the future then dont get the gears till you do that it cost 1500-2000 to do.
If you plan on keeping it like this then go with 4.10-4.30's
Old Apr 19, 2008 | 06:56 PM
Any taller and heavier tire will cause you to lose mpg's especialy in stop and go driving. A programmer will help out a little by letting you adjust shift point's and let you reset your speedometer. Driving a little slower alway's help's out.
Old Apr 19, 2008 | 07:21 PM
4.2trimble's Avatar
That helped me out so much its not even right! Accelerate slow and stay in the 55-60 range and you will get good mileage.
Old Apr 19, 2008 | 11:27 PM
MexicoDan's Avatar
I recently got bigger tires too, MPG dropped quite a bit. Got a Magnaflow exhaust and AF1 and it's almost back to normal. I figured out my tires were 3% bigger so I add that to my trip odometer when I fill up. Of course, I HAVE to drive conservative to get that gain and it's hard to do.
