really bad wobble on new tires and wheels--help
Originally Posted by *FX4TEXASGIRL*
jditta---i did get blems, but they reassured me that is was COSMETIC ONLY.
if something is wrong beyond that, pro comp should warantee them.
almost 49,000 miles. my dad works at the dealer doing only front ends, and my boyfriend was talking to him about that. he would not stop talking about it on easter.
my dad said he still has not seen but a few come in with bad ball joints on the 2004 and up f150 trucks.
Originally Posted by 1badstx
I would laugh in your face if you told me to do that. They only reason i would spin the tire is if it takes more weight than i feel comfortable with.
i would take it to sears, discout tire, anyone who could get it right, but im out of money. i got so much money wrapped up in getting screwed out of 500 bucks by 4wheelonline, plus some other expenses. 4 wheelparts should keep rebalancing till they get it right, right?
Originally Posted by Jditta
That's because your just smarter than everyone else!
If you examine your tire, you're going to have grooves, nibbles, and other small characteristics.
By following around the tire carefully, you can find a place that those characteristics cannot be found, for example the place could be smooth.
I'll take a picture tommorrow of the thread hop on my dodge so you can see what i'm saying.
Then I guess it's a good thing you don't work for Sears
I've got some good stories to go with this stuff, but that's for another time!
Texasgirl, is there another 4wheelparts branch you could take them to? maybe trying a different one might get you a better answer.
If not, ask around and find a good private tire shop.
If you were in MD i would take care of it for you!
thanks, its so frustrating. this is the only one. there is another in austin i think but thats over an hour away. its 4wheel parts, this is all they do. its not like im asking a flower shop to balance them and get it right. all they sell and do is lifts and tires. i drive alot, so i cant just ignore this either.
I've caught this thread kind of late, but I have blemished 40 x 13.50R18 MT Baja Claws that I bought from Jordan Tires in Ohio. They were mounted and balanced when I received them and once I hit the road I experienced the same wobble that you are talking about to include the bed shaking like crazy. Well it turned out the tires weren't balanced correctly the had 1/4 oz stick on weights and they needed 1 oz stick on weights in order to be balanced. The tires and wheels needed to be balanced on a tire balancing machine that is specifically made for big tires, if not the tires will seem to be balanced but when they hit the road there not. I was lucky to find an off road shop nearby that had that machine and got mine balanced and now they ride great. Before I got my tires balanced I had my gears installed at 4wheelparts in Tennessee the technician told me all my wobbling came from the tires not being balanced properly when he took my truck on a test drive. That's how I found out my problem came from my tires. they said they don't really have a machine that could balance big tires, although this struck me as being kind of weird since they sell tires up to a 52" mounted and balanced. well that's my experience. Hope this helps.
thanks, that helps too. it gives me hope. this leaves 2 options that are not for sure yet:
1. the tires have not yet been proven to be out of round.
2. both times ive been balanced they have put sticky weights. no clip ons. my boyfriend mentioned those other clip on weights too.
so here is the next question: i have monster wheels. 20x10s. can those clip on weights be used on them?
You can probaly use clip on on the back lip and stickson to balance the front.
The only thing about clip ons is if they need a lot of weight, sometimes is better just to use stickons
Quite honestly it shouldn't make that much, if any of a difference
thanks again guys. i made an appointment for tue at 4 wheelparts to have it done again.
they told me they checked to see if they were out of round last time. he said they are not, so thats good. hopefully they will give it extra attention. maybe they will test drive it to see how bad it really is. ill let you guys know. thanks bunches. : )
My truck has a horrible wobble from 60 - around 67 then it stops above 70 And its very very annoying to say the least let alone dangerous haha any ideas? and where im MD you from 1badstx ? Im on the Peninsula maybe i could bring it to you for my tire work?
