sand tires
sand tires
What would be a good tire for loose sand. I just got a job at the beach and it requires 4wd to get to one of stations. I an looking for either 33's or 35's on stock rims. I will be adding a 2.5 leveling kit and an add a leaf to the rear. Keep in mind though that it's a 95 mile ride to work so I need a tire that will last a while to. Thanks for any help you can give.
i had the dune grapplers in a 285/70 17 on my 99 f150...they rode rougher than the bfgs but are cheaper. and they are awesome in loose gravel and sand, especially aired down. mud is a different story. if you are in much mud at all id go with the tried and true bfg.
OK another question then. Would these fit with the leveling kit and aal. If so what size rims and backspacing would I need.
**** Cepek radial F C-2
Size LT375/50R18 (33x15.50R18LT)
Appx. Wt. Load 85
Range Max E
Load 3,525
Max PSI 65
Approved Rims 10.0-13.0
Measuring Rim 12
Sidewall Width 15.4
Tread Width 12.2
Overall Diameter 33
Tread Depth 22/32
Appx. Wt. Load 85
Range Max E
Load 3,525
Max PSI 65
Measuring Rim 12
Sidewall Width 15.4
Tread Width 12.2
Overall Diameter 33
Tread Depth 22/32
Originally Posted by hoss66
15.5" wide is going to be to wide for your truck. look at the 33/12.50. you will want to get 18x9 rim with about 5" of backspacing.
Yeah I know but I like mine short and fat.
