Time to replace pads
Old Feb 24, 2008 | 06:54 PM
andrewc_11890's Avatar
Hey guys, so I have had my same brakes on since i got my truck from the dealership. I now have 35 inch tires on my truck. I'm not too familiar with breaks, but I can tell that I am going to be needing to replace the pads soon.
I have been reading around this part of the forum, and i see you guys mentioning so many different things like the rotors and replacing or rotating them etc.
What exactly do I need to do to revamp my brakes. Do I just need to get new pads or what? I also have chrome wheels, so I also wouldn't want a pad that is throwing off tons of dust onto them.
Thanks for your help.
Old Feb 24, 2008 | 09:12 PM
BLUE20004X4's Avatar
I myself just go to Carquest, get new pads, the semi-metallic "blue" colored pads and the better of the choices given rotors. If the fronts have a lot of meat still on the rotor, have them machined or "turned" and get new pads. Cheaper that way. I assume you don't know how to replace them properly yourself? Take it to a shop unless you want to learn, good to have someone with experience show you, plus again, saves a ton of $$$ by doing it yourself. I would suspect just the fronts need replacing?
Search these pads, type Carquest or Wagner Thermoquiets and you'll see they are the 2 leading almost entirely dust free pads you can buy. I can't recommend them enough. If you decide to go to a shop, make sure they use good stuff, there is probably alot of good pads too, just ^ these are very noted for having a good rep.
Enough people can walk you through a brake job, it's not hard.
Old Feb 24, 2008 | 10:58 PM
What exactly are the rotors?
Old Feb 25, 2008 | 08:38 AM
Why they are what the pad makes friction with. The shiney circular "disc" behind the wheel when you look through the spokes. Time to take it to a shop. You know your pads are going when you brake from the freeway and it sounds like a growl or squeel.
