325/60/18s on my 2wd
Old Feb 8, 2008 | 08:04 PM
attworth's Avatar
Fit some tires today. 325/60/18s (33" variant.)
They fit perfectly. I had about 1/2" left to the control arm, and lots of room everywhere else.
They had some 35x13x18s but the 18s I was using weren't mine so I couldn't try them.
Pretty sure they would fit. Very enthusiastic about that fact. I may need to trim the inner fender at the back end though. No big deal there!
My friend is going to see about snagging those for me. Then comes the 35s (can you say trade in?)
Oh, these were 18x10s with 4.5" BS.
Old Feb 8, 2008 | 10:38 PM
wandell's Avatar
How much lift do you have?
Old Feb 8, 2008 | 10:51 PM
attworth's Avatar
2.5" AS.. You've already told me I can't fit 295s. It's ok though, I respect you greatly. I think my truck is just special.
Old Feb 8, 2008 | 10:54 PM
wandell's Avatar
Glad it worked out for you. Do you have any rubbing? That wheel just looks like it has more than 4.5 inches of bs.
Old Feb 8, 2008 | 11:06 PM
ddgarcia05's Avatar
How wide were those tires? I'm thinking about getting some Toyo M/T's 33x12.5x18 but I'm not sure if they'll rub.
Old Feb 8, 2008 | 11:48 PM
GIP1979's Avatar
i have a 2wd with a 2.5" level and im running 305/65/18 no rub anywhere so CANT run 295's seems to be a lie
Old Feb 9, 2008 | 01:52 AM
attworth's Avatar
295/18s are smaller than 295/17s. The 325s I fitted today are exactly the same height as my 295/17s.
Wandell - There was absolutely no rubbing. They had the same offset and same width as my current set-up. Equaling 4.5" BS. My truck is a freak of nature I suppose.
The tires were about 13" wide I would say. They were very close to the control arm, so I would be wary about going with anything more than 12-12.5" unless your BS is 4.5". Any wider than 9" and you may run into rubbing of the inner fender/bumper valence.
