Warped Rotors at 16K Miles?
Old Jan 30, 2008 | 02:18 PM
Buzzz's Avatar
Well if I don't have the darndest luck with brakes. I have noticed when stopping at freeway speeds or so a pulsation in the steering wheel that is progressively getting worse. While braking to a stop slowly I feel a go/let go/go kind of action with the brakes. My hunch is warped rotors.
Hard to believe after only 16K of mostly freeway miles. I never washed the car after driving it and I don't ride the brakes. Got a call in to bring it in. Anyone else have experience with warped rotors before?
Old Jan 30, 2008 | 02:39 PM
gpaje's Avatar
Did you have your original rotors turned? Did you change to ceramic pads on turned rotors? Either of these could get your rotors warped very easily.
Also, brake pulsation during braking could be caused by cheap pads that have left unconsistent layers of material on the rotor, which causes the pulsing during braking.
As for me, I had the same problem. My issue is that I had my cheap OEM rotors turned and I added ceramic pads, which made the issue worse on already thin rotors.
I had to buy new rotors ($55 each), which fixed the problem.
Old Jan 30, 2008 | 03:24 PM
Bonusbuilt1950's Avatar
Unfortuneately, the quality of the mtel is poor compared to years ago. You're not alone with warped rotors. It also depends on how you drive and stop. We get alot of complaints here at the dealership, not just the F-150 models. We have a customer with a 01 F-150 and we can't use factory rotors as he will warp them within 500 miles. We buy aftermarket power slotted rotors and they seem to do the trick. He waits until the last minute to put his foot on the brakes.
Barry
03 F-150 reg cab 4x4
( Ford parts man )
Old Jan 30, 2008 | 04:50 PM
Buzzz's Avatar
Nothing has been done to the pads or brakes. OEM. Man, if these things are going to warp every 16K I don't know what I would do.
Old Jan 31, 2008 | 04:36 AM
gpaje's Avatar
Simple, use non-OEM rotors. They are the same price or sometimes even cheaper than dealer priced OEMs.
Pepboys in my area is really good at pricing and installation. I have good quality rotors designed to work with ceramic pads, and they were only about $50 each.
Old Jan 31, 2008 | 07:14 AM
hivoltagefx4's Avatar
I went ahead and purchased a set of Power Slot Cryo rotors specifically for this reason. They are very good rotors. Check out the link:
http://www.powerslot.com/pages/power_slot_cryo.html
Old Jan 31, 2008 | 10:28 PM
bxstang2000's Avatar
Improper torque and sequence is the #1 reason for warped rotors. Anyway we get brand new hyundai's with 8 miles with wraped rotors. LOL Don't you just love Korean garbage.
Old Jan 31, 2008 | 11:09 PM
00Ford4X4's Avatar
Thats what I did. I have over 30K on my non-OEM rotors and have had zero problems. I got mine from Advance Auto Parts online for around $35 each for the front and $45 each for the rear. They may not be the best, but they do the job.
I believe it was metioned earlier in this post, but proper torqueing of the lug nuts is important as well.
Old Feb 1, 2008 | 11:41 AM
Buzzz's Avatar
I was thinking about the over tightening aspect. I think the pattern of tightening is more important than the pressure. Think about it, when is the last time you saw anyone tighten lugs with a torque wrench. Would 80% of us all have warped rotors? Dealers don't even use torque wrenches most of the time. Just my thoughts.
Old Feb 2, 2008 | 10:30 PM
aaks38's Avatar
to add, its also important to season new rotors by breaking them in to avoid rotor warping. Bear racing has a good article on how to do this.
Old Feb 3, 2008 | 01:28 AM
Ballin STX's Avatar
Is it normally the front which causes the steering wobble when braking at high speeds? because mine tends to do it sometimes worse then others. I was looking into new rotors as well.
Old Feb 3, 2008 | 01:50 AM
Yes, normally the front. You feel it through the steering wheel.
Old Feb 3, 2008 | 04:06 PM
JeremyGSU's Avatar
Interesting. I'm at 50k+ on my OEM rotors and they still feel fine. I've only changed the pads so far.
Old Feb 5, 2008 | 01:52 PM
bamorris2's Avatar
For me, I can tell if it's coming from the front or rear... If it's coming from the front, I can feel the pulsation throught the brake pedal... If it's the rear's, then I don't feel it throught the pedal, but I feel the entire truck pulsating. Just recently that happened. I replaced the rear rotors, and sure enough it fixed it.
Old Feb 5, 2008 | 02:02 PM
I had a front bearing go out almost a year ago. You could feel it and hear it, especially when on a curve. the dealer want $500 to replace the left on. I told them it was the right, they said no, the left. So I bought a front rotor and bearing, replaced teh left one. It was the right one. Repalce it too, and all is good. They would have charged me about $900 for both sides. I did them ***** for $325.
