What Wheel/ tire set up
Old Jan 4, 2008 | 06:31 PM
Kabby's Avatar
I've got an 05 fx4 with the AS 2.5 leveling kit, i'd like to get some 33's and run20" black mazzi hulks. Is there anyway this set up will work without any rubbing?
Old Jan 5, 2008 | 11:44 AM
wandell's Avatar
The problem will be the width and backspacing of those wheels. I'm not sure, but I think they are 10 inches wide with 4.5 inches of bs. If you find a 9 inch wide wheel with 5 to 6 inches of backspacing, you will be fine using a 305/55-20 (33x12.50) tire.
Old Jan 5, 2008 | 12:11 PM
gators241987's Avatar
again, backspacing is the key. the correct bs, and the tires should fit with minor rubbing
