Where can i find 35x10x17
I agree. The oem 7.5 inch wide wheels are 1/2 inch narrower than recommended by most tire manufactures for 12.50 inch wide (315mm) wheels but several members here and FTW have done it with no problems. One memember at FTW got over 60,000 miles out of a set of 315/70-17 (35x12.50) BFG AT KO's on his Screw using the OEM 17x7.5 inch wheels. THe only issue with doing this is it can sometimes cause the center portion of the tire's tread to wear slightly faster than normal, similar to running too much air pressure. I currently have a 315/75-16 (35x12.50) mounted on my oem (spare wheel) 16x7 wheel as a spare tire.
Originally Posted by hawg_man
probly the only company I could think of that might make those would be interco.....they have a lot of their tires in different and oddball sizes. You can fit 12.50's on stock rims, it isn't recommended but is done all the time......
