20" Goodyear Wrangler AT/S-need advise
I have a 07 F150 4x4 SC with factory 20" Pirelli tires. Looking at new rubber to fit my 20" OEM rims. Is anyone running Goodyear ATs/S 275/65/20 tires. I have a 2" AS kit up front. These are the same tires on the SD250's with 20" rims. Would the ride be rougher due to this tire being higher load rating 3800 lbs compared to a 2800 lbs tire?
Price on these tires is around $180 compaired to other in the $300+ range.
Looking for something a tad larger than the factory 275/55/20's
CMT
CMT
CMT
CMT
Here check out some of my pics.The one picture says 285 but its typed wrong and it wont let me change it.
https://www.f150online.com/galleries...cfm?gnum=10415
Are they about 34" tall? I see you have a 2.5 leveling kit in front any rubbing issuses?
Thanks for the pic's looks good.
CMT
CMT
Originally Posted by pats04xlt
yes 2.5 and no rubbing 34.1 is what there supposed to be but measured on truck about 33 7/8 thanks
Originally Posted by labman1014
do you think just a 2in kit will be enough? i dont want to go too much and i am going to add the AS aal also in the rear. my local sams can get that tire for $135 each so that is what i really want to go with.
Not sure i have the 2 1/2 and it fit fine your only talking 1/2 inch lower in front.
