Opinions? LT315/70R17 on stock 07 wheels
since im in the same situation, i was wondering the same thing. but i have an 06 xlt supercrew 4.6 v8..i have 285/70/17 with a 3 inch body lift i was wondering how big i can go without rubbing and any mods? plus i dont understand the whole 285=33's? i thought 33's were 33's lol n so on ..help plz
I would think you wouldnt want to go any bigger than a 305/70/17. 295/70/17 or a 305/65/17 would be good choices as well.
In a tire size that is not listed as the "flotation" size i.e. 33x12.50R17 would be a 306/65R17. The 305 is the width of the tire in mm, the 65 is the aspect ratio which is a % of the width (.65x305) and it is the sidewall height.
here is a good conversion tool.....
http://www.1010tires.com/TireSizeCalculator.asp
tire calc
To calculate tire size yourself is pretty easy. take the width (285) divide it by 25.4 to convert it to inches. 285/25.4=11.23. then you take your width and multiply it by your aspect ratio (70) to get the sidewall height. 11.23x.70=7.87 Then you take your sidewall height and multiply it by 2 because you have two sidewalls included in the diameter of the tire. 7.87x2=15.74 Last you simply add the diameter of the rim and thats your diameter. It probly seems complicated but after you do it a few times it is very quick and simply. You dont need to rely on a computer to do it for you. here is a recap...
285/25.4=11.23 Convert to width from mm to inches
11.23x.70=7.87 multiply widthxaspect ration to get sidewall hgt
7.87x2=15.74 sidewallx2 to get thickess of both sidewalls
15.74+17=32.7 rim dia+tire sidewallsto get overall diameter
what about a leveled 4x4? I'm curious what the largest tire that would fit the rim itself is - would the 315/70/17 fit the 7.5" wide rims? On 1010tires's calculator that comes up as 8.5-10" rim width recommended...
anyone try that yet? I think andrzej77ff's truck has the biggest tire i've seen on a stock 17" rim so far... anyone that went bigger ?
Originally Posted by Fifty150
Since I don't know, I'm throwing this out there to all the more knowledgeable members of this forum. Will the LT315/70R17 tire size on factory 17 wheels fit? Any issues with rubbing or handling? Leveling kit needed for clearance? Which brand? I've been looking at the Goodyear Wrangler AT from Walmart. It's a good price and they feel good on my Explorer.
2004 - 4x2 XL 4.6 Short Bed, Reg. Cab. AS 2.5 Leveling kit with BFG AT315/70/17 on stock 17" XLT Rims. No issues at all.
2007 - 4x4 XLT 5.4 SuperCrew 6.5 Bed. Bilstein 5100 Preload adjustable shocks. BFG AT 315/70/17 on the same rims. No issues at all.
Pictures are in my Gallery.
Originally Posted by WhiteGTSofDeath
I dunno about the other posts in this thread. But I am speaking from PERSONAL experience.
4.2 w/ 35s
Originally Posted by hawg_man
with a 4x2 you would need at least a 3'' body lift to fit that size tire........you might not be happy either with the performance with 35's and the 4.2
I put 315/70/17 with stock wheels on my stock suspension 4x2 2007 f150 , i removed the front bumper plastic and i was fine it still rubbed a little at full left turn i now have a pair of fuel wheels on it with a 15- offset and they dont rub at all !! So yes it can be done , wish there was someone that did it before me but i have found no help before so i just did it ! I have a 5.4 v8 in it and its very noticeable in power wise i'd say its 30% slower than with my stock 255/65/17 tires
