Another wheel and tire Question about backspacing
Hey,
07 SCREW Fx4
I've been reading over this stuff for a while and I just want to make sure i am making the right decisions before i dive in...
Wheels I'm considering.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
The listed info may be throwing me off. Is the -12mm of b.s. really in mm? This is where i am getting confused.
18x9
Offset: -12mm Bolt Pattern: 6-135
Rec. Tire Size: 275/65-18
Tires are the
325/60r18 Nitto Terra Grapplers
Getting a 2.5AS level kit.
Questions:
Will this be a problem with rubbing?
Is the backspacing on this wheel be 7.5 in?
tried figuring this using Offset= backspace - (rim width/2)
Is this as big of setup that I should consider with 2.5 level?
Is there anything else i am not considering that i need to be thinking of?
What it a rough estimate of what I should be looking at paying for this setup? (wheels and tires)
Thanks for all your help,
07 SCREW Fx4
18x9
Tires are the
Questions:
as far as the wheels go. The website shows it having a 4.5 in backspace. The -12mm is the offset, which it is the distance from the centerline of the wheel. Those wheels are made by American Racing:
http://www.americanracing.com/browse_dale.asp
I'm not sure on the rub but I don't think so from what I have read, but I'm sure others will chime in.
that set up is going to stick out about 3.5'' further than stock....that is quite a bit.........check out codewhitefield, he just posted and got new tires and rims, same size tires and rims, his rims have 5'' bs and he had to do some trimming. i think you would want around 5-5.5'' bs
Thanks for the help. Anyone have any ideas of wheels that look similar to those with a mix of black and chrome?
I also want to make sure that I will have no trouble with the 35's and a 2.5 AS.
Also wondering if what the average price difference is between the nitto tg, procomp, and toyo AT's are if anyone happens to know.
Thanks for all the help.
