ABS Light is on!
Originally Posted by Nismo Racing
My old mans 2001 Ford F-150 supercrew Had the ABS light come on and stayed on this morning. Anyone know what need to be fixed?
The #1 most common problem is the rear ABS sensor, on top of the diff pumpkin.
Approx $20 @ Ford for a new one.
After that, you likely will need to get it diagnosed, as it could be either front wheel sensor, wire chafing/break, or the ABS pump/ control unit itelf.
Good luck.
