Did I mess up?
First off, sincere apologies. I called Mickey Thompson(like I should have done in the first place) and they said the tires should be 34.5 just like someone mentioned earlier. I don't usually run off half ****ed. Sorry and thank you.
Bluejay & I will just whack you and call it even!
MGD
here you go....
take your width in mm (315) and divide by 25.4 to get width in inches=12.402 inches wide.
then take your aspect ratio (75) which means 75% of your width is your tire sidewall, so 12.402 x .75 = 9.301 inches on each sidewall, and you have two sidewalls to get the diameter, so multiply it by 2 to get 18.602 inches of total sidewall height.
then add your rim diameter to get total tire diameter. 18.602 + 16 = 34.602 inches.
Your tires are 34.6 x 12.4 r 16 (basically a 35x12.5r16, same thing)
hope this helps
hope this helps
