What is the best all around combination (pads/rotors)?
Old Oct 18, 2007 | 12:51 AM
masonm75's Avatar
What is the best all around combination (pads/rotors)? I want something that is easy to purchase anywhere, good warranty, all around performance, last a long time. I have searched, but just trying to verify the information I got.. Thanks for any help...
Old Oct 18, 2007 | 06:47 AM
madcat6183's Avatar
From what it sounds like people are into CarQuest Blue semi-mets and powerslot rotors. But sounds like powerslot rotors the rears on on a massive back order. Also I believe the Hawk pads get good reviews here too.
I just did the CarQUest and love them, 175 for front rotors and pads. A+++
Old Oct 18, 2007 | 08:21 AM
BLUE20004X4's Avatar
My luck has been with the Carquest (Raybestos made) "blue" semi-metallics. Lifetime warranty should be included. The rotors, I stick with regular ones, but while at Carquest just get the better of the choices, usually thicker. The things to remember are semi-metallic, warranty and better rotor. That's pretty much it.
Old Oct 18, 2007 | 09:13 AM
ThumperMX113's Avatar
Powerslots are no longer on back order.
Old Oct 18, 2007 | 10:11 AM
hivoltagefx4's Avatar
Does this hold true for the Power Slot Cyro rotors? Also, where did you get yours Thump??
Old Oct 27, 2007 | 08:21 PM
18inMD's Avatar
"NTB" Raybestos made semi-metallics???
Has anyone had "NTB" National Tire Battery install Raybestos made semi-metallics that they sell... I bought my tires from them and wondering if I should get my brakes there to.
Old Oct 27, 2007 | 09:46 PM
Do it, probably the same as Carquest (Raybestos) semi's, see about a warranty against noise and dust etc.
Old Oct 28, 2007 | 08:12 PM
beechkid's Avatar
25 Year Member
For the street
I would recommend Carbotech Engineering for the pads and Brembo OEM replacement rotors- purchased from Diversified Cryogenics. $ for $ it will be your best buy. Pads run about $120 a set, rotors- run about $15 above NAPA oem replacement units- so figure about $100 each.
Old Nov 10, 2007 | 06:35 AM
Sphinx's Avatar
Can anyone comment on how well these work for a vehicle that tows regularly? I usually tow a 5000 trailer a few times a year and it needs to stop.
