Will 37's fit?
Will 37's fit?
I have a 2004 f150 4x4. I have the procomp stage 1 lift and the bilstein 5100's that raise the front end 2" are going on Friday. I would really like to fit TOYO MT 37 x13.50 r 20. Do you guys think this will work?
Thanks,
-Quick
Thanks,
-Quick
i believe hash is correct, he does have his coilovers cranked. I have a 6inch basic pro comp with the bilsteins and would like to know if 37's will fit. Theres got to be a way to find out without having to go thru buying the tires and mounting them to find they rub.
look in my gallery. I have a pro comp stage II with the coilovers.
Mine are cranked up and I have 13.50in wide 35's. I can fit 37's under it with minor rubbing. I could fix it by trimming the air dam just a little bit
PM me and i can send you a picture of the wheel well
thats using a 5 inch backspacing wheel. The guy who installed mine has a friend with the same lift, same truck, and 37's under it.
The bilsteins raise to the same heigh as pro comp coilovers, right?
The bilsteins and AAL are on! Boy does my truck look dumb with 8" of lift and 33's on 20's!!!
I will be deciding on tires early next week and will likely go with the 37. I will take some pics of the current status and post up this weekend so you guys have something to laugh at for a minute!
-Quick
I will be deciding on tires early next week and will likely go with the 37. I will take some pics of the current status and post up this weekend so you guys have something to laugh at for a minute!-Quick
