Can I run 35 inch wheels on a 2wd with 3 inch body lift?
If you have a 4x2 and plan to use aftermarket/non stock wheels, don't even think about 35s. you would need either a 4" or a 6" lift for that.
even with just 33's, be aware of the backspacing and offset, you could still get some major rubbing, especially with any type of M/T tire since they have larger huge side lugs.
Originally Posted by wandell
If you combine a 3 inch body lift and a 2.5 inch leveling kit you may be able to fit 35x12.50's using the oem wheels. Personally, I'd stick with 33's. Also, your truck sits about 2 inches lower than a stock 4x4.
