"Help Wandell "o7 screw 35.12.50 x18
I decided to go with the procomp xtreame AT 35x12.50x18. My problem is I dont want the tires to stick out too much. I like the classic look of the mickey thompson classic ll. The wheel comes 18x10 with 6'' of back spacing. How much farther will it stick out compared to my stock set up? Should I shop around for a 18x9 instead. I chose the procomp extreame because it looked agressive for an At and it was buy 3 get 1 free. I really liked the BF KO AT also. I appreciate any advise you can give me. I'll send pics when its done.
I do have a 2.5 as with aal
The MT wheels will stick out 2 inches farther than the oem wheels. This would be the same as a set of 18x9 inch wheels with 5 inches of backspacing, which seems to be a pretty common wheel spec. So if you like the MT's, go for it. Since you only have a leveling kit, I'd stick with a 33x12.50 or 325/60-18 (33x13.00) tire.
