305/50/20 or 305/55/20
Old Sep 25, 2007 | 10:09 PM
labman1014's Avatar
ok, finally with the pics from raptor2, thanks by the way, i am about to order up some cooper zeon ltz for my oem 20s. question is: is the 1.2" in overall height difference worth $280 a set? discount tire has the 50 for $200 a tire and the 55 for $270 a tire. they are the same width, 12" and rim, 20", but one is a true 32" and the other is a 33.2".
also, what makes them rub at full lock? is it the width or height?
any opinions will be nice.......
Old Sep 25, 2007 | 10:29 PM
wandell's Avatar
I'd go with the 305/55-20's. It's a combination of tire width, height and the wheel that causes the rubbing on the control arms at full steering lock. Personally, I'd rather have that than them rubbing the fenders.
Old Sep 26, 2007 | 11:34 AM
raptor2's Avatar
labman, mine only rub the control arm when in reverse and at FULL lock and that has only happened once or twice. If I back the steering wheel off just a tad, it stops. This does not concern me what so ever now that I've had these tires for about a 1000 miles. I like the 305/55/20 over the 50. The 50 will actully look smaller than the stock Pirelli's because the sidewall is not as tall. I would call discount tire in Charlotte NC, thats where I bought mine, tell them about my deal and ask for the same, all they can say no right
Old Sep 26, 2007 | 11:45 AM
hivoltagefx4's Avatar
X2 Go with the 305/55/20. That's what I plan on getting.
Old Sep 26, 2007 | 12:51 PM
mludi's Avatar
You can't go wrong with the "55's". Their a better fit than the "50's"
https://www.f150online.com/galleries...cfm?gnum=10466
Old Sep 26, 2007 | 12:54 PM
5.4 LARIET's Avatar
I have the 305 50 20's, It all depends the look you want, the 55's are just a bit higher. The 50's give you a little sportier look.
Good luck!
Old Sep 26, 2007 | 01:08 PM
wandell's Avatar
Keep in mind his truck is lifted slightly and your FX2 is at stock height.
Old Sep 26, 2007 | 01:15 PM
r1abuser's Avatar
I got my 305/55/20's from Eric at ejonline.com for 900 bucks to my door... hope I got a good deal. Love the tires.
Old Sep 26, 2007 | 01:49 PM
raptor2's Avatar
r1, what size do you have, I checked with EJ on the 305/55/20 and his price was $1200
Old Sep 26, 2007 | 01:54 PM
raptor2's Avatar
labsman, you definatly want the 55's, I see you have the leveling kit, if you go with the 50 that tire is going to look small. My truck is stock height with the 55's and I still have empty fender space that I could fill. If I had the leveling kit I would probably go with a 325/60/20(35x12.5)
Old Sep 26, 2007 | 02:29 PM
labman1014's Avatar
also keep in mind, mine is a 2wd with a leveling kit!!!!
i sit just 0.5" higher in the front than a stock 4wd
Old Sep 26, 2007 | 02:46 PM
r1abuser's Avatar
Ahhh crap guys sorry about that. I did buy the 50's !!! $800 + $100 shipping to my door.
Old Sep 26, 2007 | 09:46 PM
5.4 LARIET's Avatar
R 1 what brand tire? post pics..
Old Sep 26, 2007 | 09:56 PM
MGDfan's Avatar
The OEM Pirelli's are 31.9" .. them 305/50's is 32", so that don't compute ....
Old Sep 26, 2007 | 10:00 PM
Kevin24's Avatar
What are you doing her MGD
