17" or 18"? Stock or AM?
Old Sep 25, 2007 | 02:52 PM
MercedesTech's Avatar
Question 17" or 18"? Stock or AM?
I have a question, and you guys have been real helpful before, thought I'd try again. My tires are getting low. I have the stock set-up with the 2.5" leveling kit and a 3" block waiting to be installed. Anyways, tires are almost done for, need new ones. I want to buy the new BFG T/A KM2 . I want a set of 35" tires. Question: Should I buy the tires for a 17" rim? or an 18" rim? I currently have the stock factory plain jane 17" rims on and I have the money to buy the tires, and throw them on the stock rims. OR I can continue to save and wait until I have enough money for a nice 18" rim (not sure how long) ? What would you guys do? Buy for 17"? then save up while I'm running them to buy a nicer 17" rim? If anyone has a pic of those 17" rims with some nobby tires on it would be a great help in deciding. Thanks ahead of time everyone.
Old Sep 25, 2007 | 05:20 PM
hawg_man's Avatar
I would go 17''. Get your tires now, it will look good on the stockers, you will save a good deal of money by buying 17's over 18's and personally I like more tire. Make sure whatever you do, when you buy the new rims you are careful, check out pawpaw's setup.....otherwise you will have major rubbing issues.
Old Sep 25, 2007 | 06:53 PM
BLUE20004X4's Avatar
I would too go stockers like hawgman said. Also, given the setup, maybe a 285/70/17 tire black sides out, or 295/70/17 if available in that tire. It looks nice this way and lots cheaper.
Old Sep 25, 2007 | 11:13 PM
You can fit a 35" tire on the stock 17" wheels and maybe get a slight rub when turning on the control arm, but to turn these tires it's better to have the 5.4 engine and 3.73 gears or lower. I would also check out the Toyo 295x70x17 MT, the 305x70x17 Maxxis buckshots or bighorns or the Nitto Terra Grappler in a 295 or 305x70x17. Once you see the new BFG mud terrains it's kind of hard to change your mind though, nice lookin' tires. Good luck!
Old Sep 26, 2007 | 12:39 PM
Ya, i am pretty set on either the Nitto Mud Grapplers, or the BFG km2. The Toyo's are awesome looking tires, and from what I hear, they perform great, but everyone and their mother has one. A couple people on my block alone have a set... so I want something else. Haven't looked much into the others, like you said, once your set its hard to change. plus I am looking for a real aggresive off-road tire since my truck uses its 4x4 on a regular basis (PawPaw, I think you have a good point. I didn't even think about the power loss issue, I may run 33" tires for that reason alone, i will look into those other tires you mentioned) . Anyways, thanks a lot guys, I appreciate the opinions, and u convinced me to get the tires, then wait for rims later down the road. Its the way i was leaning, and u just helped, thanks! Once the Dynopro A/T (crap tire) wears out, i will get the new tires and post em on here. Again, thanks
