Who makes a 33\34" tire for 22" rims?
Next step up would be a 35" tire. But then you will need a lift. I have never come across anything bigger than a 45 for a 22" wheel. But Wandell is right, you essentially already have a 33" tire(actual measurement is 32.8 inches). It is just a street look which may be what's throwing you off.
When mine run out I will be jumping up to 35" M/T's.
They were not cheap, around 275 a tire. I love them. But I had gotten a really good deal on the rims so it worked out in the end.
Do you already have the rims? If not, I would really consider getting 33" tires with 20" rims. I think you will be much happier. You really become limited on choices when you go to a 22". If I had not gotten the rims so cheap I would have definitely gone with 20's.
The 305/40/22's are only 31.60" in diameter. Check out this link it shows the difference in tires.
http://www.1010tires.com/TireSizeCal...?action=submit
Originally Posted by jb1dsl
Joe,
How much did your toyos run you, I found some Cooper Zeon Ltz a/t fors 210 a tire (305/40/22). Will I clear 35's with a leveling kit? Do you have any pics of your truck on 305/40's
