06' 150 right rear inside pad shot others are fine???????anyone know why?
Old Sep 5, 2007 | 02:17 PM
jpaints's Avatar
I hear it grinding and thought well it has 37k mile so i looked and saw all looks ok then looked at the insides and the right rear inside is shot?
any help!! weird usually they are all bad?
Old Sep 5, 2007 | 02:58 PM
efuehrin's Avatar
That wear is usually associated with power braking the truck. Don't ask me how I know that!
Old Sep 5, 2007 | 03:11 PM
mkosu04's Avatar
do you mean the parking brake? (i.e. the part that looks like a small drum brake)
If that is the case, you may have had and issue with the parking brake that caused it to drag during normal driving. But I would think you would feel that... it should have pulled to the right. And you probably would have smelled the very hot brake when you stop and got out (maybe not as it is passenger side?)
NEED MORE DETAILS (and pictures)
or... this just hit me... by "inside pad" do you mean that you have more wear on the interior side brake pad than the outside brake pad??? (on your calipers that is). If that is the case, it could be an issue with the pins having seized and all the braking being performed by the piston side of the caliper?
again... need more details, and pictures
a general note for all members - if you are posting questions, include tons of information... and pictures... trying to state your problem in one line makes it very hard for those of us that know to diagnose an issue.
Old Sep 5, 2007 | 07:28 PM
F151's Avatar
Yup, sounds like a caliper hung up...
Old Sep 5, 2007 | 09:07 PM
jpaints's Avatar
yeah it was the interior side of the pad was down to the metal
so i replace all the rears pads all seems to be ok i hope? the inside of the rotor is a little worn but all the others were fine and had more than a 1/4 inch left? must have been the caliper hung up-at least the pads r easy to change
Old Sep 6, 2007 | 09:12 AM
mkosu04's Avatar
when you changed them - did the pins slide easily??? You may need to pull it back apart to clean/grease the pins. Otherwise you'll have the same issue again.
Old Dec 24, 2007 | 01:39 PM
jpaints's Avatar
great i know have the same issue again!!!!!!!!!!!!lol
same pad same problem maybe a bad caliper?
Old Dec 26, 2007 | 08:43 PM
adeese660's Avatar
Sounds like you need to lubricate all external parts,slide pin ect...I think the caliper is putting pressure on the side with the piston and not on the other side,which tells me it needs some lube.Unless you have a piston on the inboard and outboard side of caliper,if that is the case,get another caliper.
Old Dec 27, 2007 | 09:44 AM
scott1981's Avatar
Yup nailed the issue on this one. I usually use marine grease and have never had the problem again. Usually water/mud is the cause of these pins hanging up
