305/70/17
Greetings all,
Im new to F-150 online and wanted to add some insight on the tire question.
Maxxiss Buckshot Mudders are the best tire for the money, and WILL take you anywhere. I've had mine for 4 years and have put 36,000 miles on them.
i hope i helped someone
plus 305/70/17 is the biggest tire you can fit under a stock truck
i've had them almost 4 years
everytime i change my oil i rotate them 2 of them still have about 10-15 thousand left and the other2 have about 2-5 thousand left
im trying to fit 315/70/17's under there now
thanks for the props you gotta hot truck too
Both trucks look great
I debated for a long time to just stuff 305's under my truck.My 35's will be on this weekend finally
Mr.Green i am pretty sure 35's will fit with your stock rims but expect some rubbing.I am not sure if you have to trim the front valence??or how bad they actually rub?Maybe someone else will chime in!!
i trimmed a little off the driver side fender well
i dont wanna trim the front valance theres so many more options at 315/70/17 than with my tires but i do love them and does any one else with them
do you have 35's without any lift?
what kind are you getting?
I am putting a 3inch body lift on my truck this weekend.For tires i went with the Mastercraft Courser MT in size 315/70/16.I am putting them on 16x10 Mickey Thompson rims.The Mastercrafts are also a cheaper tire but they are made by Cooper tires.They are about the same price as the buckshots and are also supposed to wear great and are very agressive.For the Mastercrafts i paid $775 out the door balanced for the 4.
These were for 16inch tires.The 17's are more $$$.When it is all done i will have about $1600 into it for tires,rims and lift!!
[/IMG]
[/IMG]
