ABS Light?
Old Sep 4, 2007 | 02:46 PM
zambonimaxx's Avatar
ABS Light?
Hey fellas, I noticed after I got hit my ABS light will come on after getting on an off-ramp and braking, or a short stop. It never did this before, even after some intense braking, and other things, so why would it start now? My axle shaft is bent, and the berrings are shot (some other stuff too I don't have the list in front of me) but why would it start now, did the Hit and Run effect it then?
~Phil
Old Sep 4, 2007 | 03:33 PM
mkosu04's Avatar
search all the other ABS light postings
theres a good chance the accident damaged a sensor used by the ABS system
Old Sep 4, 2007 | 06:31 PM
O.K. thanks! It has become more frequent and just turns on at startup now :-/ so I dunno...we'll see tomorrow when it gets fixed.
~Phil
Old Sep 4, 2007 | 07:04 PM
Raatikainen22's Avatar
~Phil
Mine just came on after I put in my new fuel filter.. then i heard a weird noise, turns out it was my ABS pump or something like that.. cant remember what the guy told me exactly, but now i'm drivin without ABS for a couple of days
Not sure how the ABS could have been affected by the filter swap..
Old Sep 5, 2007 | 08:10 AM
mkosu04's Avatar
sounds like coincidence to me
Old Sep 5, 2007 | 12:20 PM
dirt bike dave's Avatar
Brake dust from pads or worn disks can get on the front sensor and cause the light to come on. Even if you have rear ABS only, the truck has sensors on the front wheels. Try cleaning those sensors and see if the light goes off.
Old Sep 6, 2007 | 11:10 PM
O.K. found out what the light was on for...They said at the stealership that it was the Drivers side front Speed Controller?! Where is this located and how hard is this too fix, do they brake or just get dirty or somethin'?
~Phil
