285/65/18 or 305/65/18?
Im a little torn over which BFG A/T KO size to put on my stock FX4 18's. I know that they both have their pro's and con's, price versus looks, but Im just not sure. Any advice on the subject? Thanks.
Pics of both tires on a similar ride would be greatly appreciated also.
Depends on what you want to do, if you put a leveling kit i'd go with the 305's if you don't plan on putting a leveling kit i'd stick with the 285's. I have a 2wd with the leveling kit and went with the 285/65/18. I'll look around and see if I can find some pics for you.
I am now strongly considering the 275/70/18 Cooper Disco S/T's or the Courser C/T's as a option. Still wider than stock 275/65/18 and about 1.5 inches taller than stock. Any advice on either of these tires for the application?
I had a post about both these tires not to long ago.
I had the 305's put on and they rubbed a little when I turned right or left. Also they they were touching my mud guards as well.
I don't want to take the mud guards off, so the I am going with the 285/65/R18's for my 05 4X2 and I have a 2" AS lift kit on the front.
Here's that thread.
https://www.f150online.com/forums/sh...d.php?t=294541
Also, remember the bigger the tire the more it will hurt your MPG's.
Good luck with your decision.
Here's that thread.
I will post some pics today when i find out how. I have a 3in truxxs leveling kit and 1.5in autospring block in the rear.(couldn't wait for 2.5 autospring because new tires had to go on before holidays) I had the BFG 305AT.Go with the 305/65/18
This may work
Hope you get some ideas for your truck https://www.f150online.com/galleries...cfm?gnum=10299
This may work
