rotors and pads
Old Aug 22, 2007 | 01:59 PM
5.4SCREW's Avatar
rotors and pads
Hello, I am in need of pads... The rotors are good, but I will turn them when I replace the pads. Question, I want to run the EBS GREEN PADS with freshly turned stock rotors. Will that work, or should I just get the R1 dimpled/slotted with their kevlar extended life pads. Will it make much difference with the stock rotors? Will the EBS pads work well with the stock rotors? Any help will be appreciated...
Thanks,
Don
Old Aug 22, 2007 | 02:08 PM
05supercrew's Avatar
Ive never used the EBS green pads but with fresh turn rotors I dont see a problem. I have the R1`s and they are a great rotor and the pads work a lot better then stock. There is still dust but not as bad as the stock ones.
Old Sep 6, 2007 | 06:47 PM
xwerx's Avatar
I have the EBC greenstuff and their dimpled slotted rotors installed on my 05. Just came back from a 4000 mile trip to the mountains and can not say enough good things about the set up. I would highly recommend this product.
