2.5" levelling kit
Old Aug 8, 2007 | 02:33 AM
wweaver11's Avatar
2.5" levelling kit
well tonight i finally did it and bought a 2.5" levelling kit for my 2004 f150 4x4. now i am having second thoughts about it because someone told me it would sit up higher in the front. but on with my question
what size tires can i run with my stock 17" rims once my truck is levelled?
Old Aug 8, 2007 | 03:17 AM
gonefishin10's Avatar
35's will be your limit...but you most likely get some rubbing at full lock.
Old Aug 8, 2007 | 07:32 AM
hivoltagefx4's Avatar
I have a 2.5" kit and mine sits perfectly level. If you look/ask here, most of the guys running the 2.5" kit have trucks that sit level. As for tires, I'd stick to 33's. This way, if you decide to get after market wheels, you can do so without worrying about rubbing. I say: "Go for it" You'll love the look.
Old Aug 8, 2007 | 11:16 AM
mattyb777's Avatar
I believe that it sits level...but the way the wheel wells are shaped, the lines of the truck make it look like the front sits higher. Add-a-leafs will take care of that though...
Check out my gallery.
2" AS with 305/70/18 (35x12)Pro Comp Xtreme MT, Pro-Comp Add-a-leafs
Old Aug 8, 2007 | 07:13 PM
On your stock 17" wheels you can run up to 35x12.5x17's but they may have minor rubbing on the control arms. A 285 or 295x70x17 will clear easily!
Old Aug 8, 2007 | 07:16 PM
wweaver11's Avatar
thanks guys i saw a truck like mine at the walmart today that was levelled with 285/70/17 bfgs on it. looked very sharp. wish i could have talked to the guy to see what inch levelling kit he had.
thanks for the help
Old Aug 8, 2007 | 07:35 PM
Weaver, I know you Bama guy's like mud tires if so check out the Maxxis Buckshot's in a 285x70x17 also they make a 305x70x17 these are nice tires at a low price and would look great on a leveled truck. Just a thought!
Old Aug 8, 2007 | 07:45 PM
skid212's Avatar
Here's mine. Sits level.
Old Aug 9, 2007 | 05:10 PM
Meatwagon's Avatar
Mine leveled out 39 3/4" in front and back both now an 5K ago when I installed it.
My gallery has pics of 35x12.5x17s on stock 17s.
