Need Help Finding A Tire
Old Jul 18, 2007 | 11:46 PM
Akornz's Avatar
Originally Posted by ameration
I was able to fit 35x12.50R20 Cooper Discoverer STT M/T's on mine with just an AS 2.5" Leveling Kit (I also have a 1.5" AAL in the rear). You may need to trim though in order to fit the 35's as each truck sits slightly different (I also have aftermarket wheels).
The tire shop that I got them from ordered me a set of the 35x12.50's and the 33x12.50's in case the 35's rubbed too much. The 33's were not much noticably larger than the stock 275/55/20 Pirelli's (31.9") so I was really glad that the 35's fit. They were much more aggressive looking, but barely larger.
I really like the look of the 35's on a 20" wheel. The 33x12.50 R20's look too low profile for an off-road tire in my opinion. If you can only fit 33's, then go with an 18" wheel. If you can fit the 35's, then go with a 20" wheel.
Check my gallery for more pics of my set up.
Thanks for all the input, it is really helpful. I really like the setup on your truck Ameration. Now that I think about it I guess 33's wouldn't be much larger than what's on there now, so if I wanted it to look different than 35's would be the way to go. I think I'm really more interested in a wider look on the wheels/tires, so do the 12.50 really look wider than the OEM's?
I would do 20's but from the ones I like they would run me $320/wheel compared to the 18's which would be $185 (man so freakin' expensive) and I guess if I can't get 35's then they would look too low profile. You mind if I ask how much you paid for those 20's?
Old Jul 18, 2007 | 11:50 PM
Akornz's Avatar
Speaking of leveling kits, the shop that I was working with said they don't carry the AutoSprings (which sounds like a popular one from forum members) and they have another brand like Revo?? (or something like that) and it'll cost $250 installed. I was quoted by LesSchwab that their leveling kit was $125 plus $60 installation (is a leveling kit the same thing as a "coil spring spacer"). Should I try to get the Autosprings since they have a reputation that many are going with? So any input on this
Old Jul 19, 2007 | 03:18 PM
rednecksims's Avatar
For some reason I wanted to go with 22s but 20s are sounding more realistic for what I want, but Ill continue to look. Ameration how do your tires ride on the highway? I will definately add a leveling kit when I add the wheels. If I put on 35s do I need to regear?
David
Old Jul 19, 2007 | 10:23 PM
wandell's Avatar
Whether or not you have to regear with 35's depends on your powertrain and how you use your truck, but it is always a good idea.
Old Jul 20, 2007 | 12:59 AM
keith_bennett's Avatar
Regearing is a good idea. If you have the money, go for it.
Old Jul 20, 2007 | 11:27 AM
chumFX4's Avatar
325/60 (33x13) on 18" rims......
Old Jul 20, 2007 | 03:26 PM
Akornz's Avatar
Sorry to ask, but what is "re-gearing?" If I decide to go with 33's, do you still recommend re-gearing? Thanks
Old Jul 20, 2007 | 03:30 PM
built54's Avatar
I love my terra grapplers 305/50/20
