oh god, im so torn between BFG ATKO 285 and 305!!!
Originally Posted by YOMAN
i was told that 285 65 18 BFG ATKO is not really actual at 32.7, its almost right at 32.5 to 32.2".
can any one please use tape measure to measure your 285 to see whats actual size tire is?
Thanks!
YOMAN!
Thanks!
YOMAN!
i want to clarify my measurements, in case you measure from the ground as ive seen some people do. The actual tire diameter is measured at axle height and across the tire.
Actual top of my tire is NOT 33" from the ground. But my set is a true 33" diameter.
Before anyone tells you differently that they "only measure 32 or sumthin".
I am surrounded by specs. with a tire business in the family.
PS, anybody got any actual measurements on their 305's ? I might go that route after my 285's wear out and I would probably go with a small lift or level kit.
Well, it look like that i cant get BFG 285.
I went to some local store and some of them said its HARD to get it and most of them are $265-279 each so i decided to get 17" rims with 33" for SAME amounts.
I think i ll go for Nitto 295 70 17 with Either ATX mojava 17x9 or Pro Comp (black) 7089 17x9 4.75" BS w/ -6mm.
Thank you all!
YOMAN!
Thank you all!
YOMAN!
