Rotors For Carquest Blues..??
Old Jun 19, 2007 | 12:00 AM
Ratz Azzz's Avatar
I'm thinking about throwing some Carquest Blues on my 04 Screw...If you guys could recommend a decent set of rotors at a good price I would apprecite it greatly...Thank You all in advance..!
Ratz
Old Jun 19, 2007 | 12:35 AM
bamorris2's Avatar
Ratz
Without breaking the bank (Powerslots), Napa makes a pretty good rotor for our trucks. I have their Ultra Premium rotors. Quality seems to be very good.
Old Jun 22, 2007 | 06:43 PM
BlacknGold's Avatar
Registered User
I just bought these www.frozenrotors.com. I know they are not the cheapest but are a good investment. I got the power slot versions and they brake ALOT better. I did notice that the carquest pads smell funny.
Old Jun 22, 2007 | 10:14 PM
BLUE20004X4's Avatar
While at Carquest, get the better of the choices for rotors, usually they ask ya if you want the cheaper, or the more expensive, go more expensive. Not much else is needed to be known, a rotor is a rotor, some are thicker and less prone to warpage etc, that explaining the more $$$.
Old Jun 23, 2007 | 01:39 AM
SRockwood's Avatar
Contrary to popular advice here, I bought the el cheapo China-rotors since they work so well on our racecar. So far, I've towed with them and got stuck in some downhill rush hour traffic (0-30-0-40-0-50mph over and over again down the Cajon Pass, a pretty steep grade here in So Cal) and the blues I have were visibly smoking. No warping at all, hell no grooves or anything other than perfectly flat wear. I've also had to do some downhill stops with about a pallet's worth of cinder block and another occasion with 22 90lb bags of concrete in the back on the same hill (pretty damned steep hill, ~5o-0 mph, Dad needed something larger than his Frontier to haul this stuff) with no ill effects.
So, despite warnings my rotors would warp and cause my ultimate doom, they've worked they way they should.
Old Jun 24, 2007 | 02:28 PM
98Navi's Avatar
You can usually get away with the cheaper rotors, but less probelms develop using the more expensive premium name ones. Bendix, Wagner, etc.. all cost more, but they usually don't go foul on you as "whitebox" rotors tend to do in some cases.
Old Jun 24, 2007 | 04:09 PM
hivoltagefx4's Avatar
Anyone ever try rotors from R1Concepts? I'm thinking about getting a set but would like to see if anyone has tried them yet?
There site is:
http://www.r1concepts.com/
Old Jun 26, 2007 | 04:55 PM
starplex's Avatar
I too am interested in knowing if anyone has tried the R1concepts rotors.... Seem to be a good price for what they are offering.
Comments please.
Old Jun 26, 2007 | 04:59 PM
I went with the Raybestos since that was what the parts store had on a Saturday. Thicker than the factory rotors. Had to replace them for bad bearings. No problems at all.
Old Jun 27, 2007 | 08:53 AM
05supercrew's Avatar
Someone on this site has them and said they work very well. But R1 is in the middle of relocating there business. I have been trying to contact them for 6 days now and no one has return my call and most of there mail boxes are full. Im going to look else where now.
Old Jun 27, 2007 | 09:21 AM
Is anyone using these Car Quest Blues with 33'' tires? And how is the dust on these pads?
Old Jun 27, 2007 | 10:08 AM
Something to keep in mind if/when you get ready to do the rotors, assuming you have a 2-wheel drive. The nut holding the rotor on takes a huge azz deep socket. I think it was maybe a 57mm. I know it was between 1 1/4" and 1 1/2". Not a socket many folks have in their box.
Old Jun 27, 2007 | 12:04 PM
Thanks, I do have the sockets but my truck is 4x4, I just removed the decals. Im looking to do this in the next 2 weeks.
Old Jun 27, 2007 | 02:55 PM
I just ordered rotors from R1 back and front slotted and dimpled not drilled and kevelar brake pads shipped to my house $401.99 Its going to take 8 working days to get to me. You can order the rotors the way you want them either drilled, slotted or dimpled or a combination.
Old Jun 27, 2007 | 03:14 PM
Screw-Me-05's Avatar
Originally Posted by 05supercrew
I just ordered rotors back and front slotted and dimpled not drilled and kevelar brake pads shipped to my house $401.99 Its going to take 8 working days to get to me. You can order the rotors the way you want them either drilled, slotted or dimpled or a combination.
FROM ? r1concepts
