ABS Unit wont turn off
on
It almost HAS to be a stuck relay. Check your owner's manual for the fuse block map & find the 2 relays for the ABS. With everything connected normally (& the pump running abnormally), pull each of the 2 relays to find out which makes the motor stop. Swap a working relay (like the horn) into that position & see if it behaves normally. If so, just pick up another relay at a junkyard, parts store, or even Wal-Mart.
If neither relay stops the motor, you have a wiring problem. If the working (horn) relay also makes the motor run, you have a wiring or ABS module problem.
