The Big Squeeze
Old Jun 5, 2007 | 03:23 PM
Foxacrombie's Avatar
The Big Squeeze
04 2WD Screw 2.5 AS and 3" BL -
Will 315 70 17 Nitto Dune Grapplers on the 17x9 MM 951 w/ 4.53" BS and -12mm offset fit? I know it will be close. Should clear the control arm, but will it clear the bumper by only having to trim the valance? Also, do you think it will look too stuffed? Below are pictures of my current set up. I'm running a GYW ATS 275 65 18. (32" Diameter). I want my tires to stick out in a wide stance approx 1.5-2.0 inches past the fender wheel. I'm not confident that I can do this with the 34.4 inch Nitto Dunes. Any and all recommendations would be greatly appreciated! Thanks.
Front Wheel
Back Wheel
Old Jun 5, 2007 | 04:19 PM
wandell's Avatar
Yes, they should fit with some minor trimming.
Old Jun 5, 2007 | 04:59 PM
Tight fit, but the bodylift ought to help out a lot.
