2007 f-150 4x4 screw
Old Jun 4, 2007 | 11:36 AM
T-Boune's Avatar
Hey guys I've been reading all the posts and have decided on a 20 inch wheel(helo maxxx 6 or motto metal) but need help with a tire size. I plan on puttin a 2.5 leveling kit and an AAL in the rear. Would a 305/60/ 20 a/t tire work? From reading all the posts I think I need a 5.5 - 6'' backspace on the rim to prevent rubbing? I want the tire to stick out a little past what the stock tire did. Am I on the right track? This Forum rocks!!!
Old Jun 4, 2007 | 12:29 PM
wandell's Avatar
That would be a 34x12.50-20 tire. It should work with a wheel with 5.5 to 6 inches of backspacing.
Old Jun 4, 2007 | 12:41 PM
T-Boune's Avatar
Wandell
I having a hard time finding that tire size. Any suggestions?
Old Jun 4, 2007 | 12:56 PM
wandell's Avatar
I thought you had seen that size somewhere. I've never seen it listed. 305/55-20 (33x12.50), 35x12.50-20 and 325/60-20 (35x13.00) are the most common sizes.
Old Jun 4, 2007 | 01:44 PM
T-Boune's Avatar
Wandell
That size came up on a tire calculator but I couldnt find it.
I found a BFG KO 285/65/20 it was 34.5 high but only 11.2 in width on a 8.5 inch rim and 6'' backspacing. Could I get the added width by using a wider rim or less backspacing? I wanted it a little wider than 11.2 Any suggestions ?
Old Jun 4, 2007 | 11:31 PM
wandell's Avatar
Using a 9 inch wide wheel will make the tire appear wider.
