Rize wheel fitment question
Old May 29, 2007 | 07:19 PM
FX4life's Avatar
I know rize recommends 4.5" of backspacing, but the wheels I was going to get XD series Monsters have 5" of backspacing. Is that going to be a problem? I called the place in dallas that will be doing the lift and they didnt think it would work, but where going to look into it. I dont know much about wheel fitment, so I thought id ask you guys!
Here's the info on the wheels:
Part Number: W/PXD77821067212N
20x10, 6 on 135 / 6 on 5.5 Bolt Pattern;
Back Spacing = 5.02 in.;
Offset = -12 mm.;
Hub Bore = 106.25;
Finish = Chrome
Old May 29, 2007 | 08:09 PM
wandell's Avatar
Since they are 20's, I think you will be fine.
Old May 29, 2007 | 08:29 PM
FX4life's Avatar
Thanks Wandell, I was hoping to hear good news! I beleive he said the problem potentially would be the tie rod?? I beleive that is what he said. .
Old May 29, 2007 | 09:58 PM
MrToyMan's Avatar
I have a 6" rize with a Pro Comp Wheel that has a 5 inch backspacing and i do have some rubbing issues. I e-mailed Rize with the pictures below and they stated that this is normal.
This is the e-mail response i got from them:
" Sorry for the delay in responding. That is normal, those are the bump stops so you don't turn too far. If it is creating any issues with the way the truck drives please bring it to our attention. Thanks Rize Ind.
----- Original Message -----
To: sales@rizeind.com
Cc: info@rizeind.com
Sent: Wednesday, January 03, 2007 5:13 PM
Subject: Is this an Installation Issue ?-Second Request
Hi,
I recently bought your 6" Lift Kit thru one of your authorized Dealer's Tom's Tire in Signal Hill CA about 3 weeks ago. I have a 2006 Ford F-150 FX-4 4X4 with a 35" X 12.5" R18 Toyo Open Country MT.
Your Ad said a 6" lift will clear a 35" tire but i am still having some rubbing during turns. I just checked and i noticed some grinding. Please see attached pictures.
Is this an installation issue ( will it affect the alignment of my truck) and how do we go about in having this fixed. I have also attached pictures of all the parts the dealer had taken out of the truck when they installed the kit."
Old May 29, 2007 | 10:30 PM
FX4life's Avatar
Hi,
Thanks for that reply MrToyMan! does yours rub on the frame at all? As my truck stands now w/ the 2.5" AS and 305/65/18 on stock FX4 rims they rub the frame and the bump stops like yours are. Yours are the rim rubbing, or the tire and how severe is the rubbing (i.e.- turns, bumps)? Do you guys think I should just go ahead the wheels if the rubbing isnt too severe?
Old May 29, 2007 | 10:45 PM
MrToyMan's Avatar
No other rubbing except the ones pictured.
Thanks.
Old May 30, 2007 | 10:02 AM
wandell's Avatar
What size are your wheels?
