size help
Old May 8, 2007 | 05:52 PM
ebfogg22's Avatar
size help
i have a 05 screw 4x4 with 2.5 as. Im having trouble deciding. I have searched around and cant tell what looks better, 18" rims with 33's or 20" with 33's. Any one with either setup please tell me if the tire 2 rim ratio looks go or if you regret going one way or the other. It does go offroad alot. I would love to do 20" with 35's but lift laws in mass. prevent it thanks in advance
Old May 8, 2007 | 06:33 PM
Smell54's Avatar
im not sure how wide you want to go but i put on a goodyear wrangler ats 275 65 20 which is a metric 34" tire and nitto terra grapplers have the 65 20 size. and everything still fits w/ the 2.5 as
https://www.f150online.com/galleries/....cfm?num=13593
Old May 8, 2007 | 08:38 PM
wandell's Avatar
Personally, I'd go with a 325/60-18 (33x13.00) tire on an 18x9 inch wheel with 5 to 6 inches of backspacing (depending on how far you want the tire/wheel to stick out).
Old May 8, 2007 | 09:32 PM
chumFX4's Avatar
PHOTOS
What Wandell says, I have! I am STOKED with the look of these tires and rims
Old May 10, 2007 | 07:46 PM
ebfogg22's Avatar
will i have any rubbing with kmc xd diesel 18x9 5" back spacing with terra grappler 325/60/18 any one have the same wheel size and backspacing
Old May 10, 2007 | 08:09 PM
wandell's Avatar
If you do, it will be at the rear edge of the front wheelwells where you can do some minor trimming but I doubt you have any.
Old May 11, 2007 | 12:01 PM
chumFX4's Avatar
Thats exactly the setup I have! Like wandell said, I had to trim the lower fender flare a little bit, otherwise, it's great!
Old May 11, 2007 | 11:39 PM
rafnaderfx2's Avatar
does anybody know what kinda 18" rim would fit on a 35" tires? and what bolt pattern is a 4x2 crew cab? i know there are some rims that are thinner and designed for cars. thanks
Old May 12, 2007 | 12:44 AM
mt_b8's Avatar
18x9 wheel for a 35x12.50, if your truck is 04-present, your bolt pattern is 6on 135mm.
Old May 14, 2007 | 11:55 PM
aftermarket's Avatar
Originally Posted by chumFX4
PHOTOS
What backspacing are your rims? Love the look and stance of your truck from the front.
Old May 17, 2007 | 11:35 AM
chumFX4's Avatar
18x9 with 5" backspacing....
Thanks for the compliment!
