Newbie Question about 9.5 tires and rims 8.5
Old Apr 25, 2007 | 10:16 AM
kcmasterpiece's Avatar
I am looking at purchasing some Toyo's 305/50/R20 (Toyo's website had 9.5 in bold).
The rims that I want says 20 x 8.5.
I am missing something. Will one of you vets fill in the gap. Will the tires fit?
The Toyo website has 8.5, 9.5 (Bold) 10.5. What does all this mean? Am I hitting my head against the wall or losing something if I purchase the rims, 20 X8.5 for these Toyo tires?
Old Apr 25, 2007 | 11:44 AM
APT's Avatar
APT
Those tires are more than 9.5" wide. 305mm/25.4 mm per inch = 12" wide.
The three numberws are minimum rim width, recommended rim width, and max rim width for the tire. You'll be fine with those tires and the 8.5" wide rims.
Old Apr 25, 2007 | 11:56 AM
Thanks APT,
I fill better going ahead and purchasing the rims that caught my eye.
Old Apr 25, 2007 | 01:19 PM
I have another question...
I orignally wanted to put some 22's on my Screw. Can I add some 22's without needing a lift kit or suffering from the tires rubbing again the body?
The tires in question are
305/45R22 118V
295/30/R22 103Y
or
LT325/50R22 122R
Old Apr 25, 2007 | 03:23 PM
APT's Avatar
APT
305/45R22 is about a 33" tire and should fit fine w/o a leveling kit.
295/30R22 is a 29" tire - would look silly on a 4x4 and the load rating is too low for your truck.
325/50R22 is about a 35" tire. That would be hard to make sut w/o a leveling kit.
The two tire sizes that would fit require certain offsets to fit.
Old Apr 25, 2007 | 04:01 PM
APT,
What offset would work for the 305/45/R22?
Thanks for answering my questions.
Old Apr 25, 2007 | 10:10 PM
wandell's Avatar
My 22x9.5 Eagles have 6.7 inches of backspacing. I know it's an Expy, but the bolt pattern is the same as the F-150 meaning the wheel is also meant to fit them.
Old Apr 26, 2007 | 11:15 AM
APT's Avatar
APT
Minimum Offset will depend on how wide the wheels are. Wandell's 9.5" width are good @ 6.7", but an 8" wide rimm would only need about 6" of offset.
Old Apr 26, 2007 | 12:43 PM
wandell's Avatar
I agree.
Old Apr 26, 2007 | 07:19 PM
The R22 tires that I am scoping out suggest a 10 - 12 inch rim. I am wondering what would I gain if I go with the recommended 11 inch rim instead of going with the minimal 10 inch. So what offsets would I look for:
10" rims
11" rims
Old Apr 26, 2007 | 08:21 PM
APT's Avatar
APT
10" wide rim = 7" backspacing.
11" wide rim = 7.5" backspacing.
Old Apr 30, 2007 | 11:43 AM
APT that for the information. I will now look for some nice rims.
