Backspacing and Offset
Old 04-11-2007, 02:42 AM
outlawz28's Avatar
Registered User
-12mm 4.5" BS or +30mm 6" BS. What should i go with on a 33x13.50R20 tire. I am also thinking of if i shoudl go with a 33x12.50R20. What do you guys suggest I go with on a 05 F150 4x4 leveled. What would make the tires stick out more.
THANKS
Old 04-11-2007, 03:25 PM
wandell's Avatar
It just depends on the look you want. The wheel with 4.5 inches of backspacing will stick out more, but you will probably have to do a little trimming, especially if you go with a 13.50 inch wide tire.
Old 04-11-2007, 08:00 PM
djh1121's Avatar
I like the "wide" look...
Quick Reply: Backspacing and Offset
