How to read tire sizes
Originally Posted by andrewc_11890
how exactly do you read a tire size what does each number mena like in 325/65/18 i know the 18 is rim size, but what is the other and how do you knwo from that measurement how many inches the tires are.
thanks
thanks
First number is section width in milimeters. Second number is percentage of sidewall height to section width.
So, 325mm wide / 25.4 mm per inch ~ 12.8" wide
65% of 325mm = ~8.3" of rubber between the rim and road
There are two pieces of rubber on a diameter of a wheel so 2*8.3" + 18" wheel = 34.6" diameter tires, or what most people call a 35" tire.
Tirerack
s Tire Tech Page has a little more details. Remember, these are theoretical sizes as each tire brand/model will be slightly different.
Tirerack
