A little math...
Old Apr 9, 2007 | 11:59 AM
ross2388's Avatar
A little math...
Ok so I was driving back home from easter weekend and I got to thinking about something while I was driving. I guess I just want a second opinion on this or to be told I dont know what the heck Im talking about. Here it goes..
I went from 265/70/17 (stock) to 285/70/17. The tire calculator said my speedo changed by about 2.5 mph. If I'm going 70, Im really going 72.5.
So...[1-(70/72.5)]= .035 or 3.5% change from stock. Also, I looked at my odometer as I passed every mile marker and it was off by just small amount every time. But as I kept track of the mile markers and my odometer, it started to be off by alot after a while. SO, does this mean that odometer is off by 3.5% as well?
If this is the case, I should take 3.5% of my trip mileage and add that on to my total? For example.... I had traveled 301 miles on my last tank of gas. (.035x301) = 10.535. So 10.535 + 301 = 311.535. My mileage divided by the amount of gas used (311.5 miles/22.6 gal) = 13.78 MPG as compared to 13.3 MPG if I hadnt accounted for the percent that it was off.
Its not really important at all but I was just curious to get other peoples opinions on if I'm on the right track
Old Apr 9, 2007 | 12:12 PM
smokestone's Avatar
your odometer is off
Old Apr 9, 2007 | 12:13 PM
Bryndon's Avatar
You are on the money. Basically everything that is based on mileage ends up off - MPG, MPH, Odometer reading, etc.
Old Apr 9, 2007 | 12:16 PM
laxwarrior013's Avatar
yes
Yes uve got it right. i have 325 60 r18 so mine is off by about 5%. But yeh If my knowledge is correct then you are doing it correctly..
Old Apr 9, 2007 | 05:09 PM
ranchhand99's Avatar
yeah, that sounds about right. i just got my 285 BFGs put on Friday and I love em. Odometer just a little off, a trip that normally takes a little over 52 miles came out to be just over 50 miles with the new tires compared to the 265s. Will all be taken care of when the TP tunes are installed!
Old Apr 9, 2007 | 11:10 PM
ross2388's Avatar
Hey, Thanks for all the replies. I was hoping I was right about everything I had thought about. A second opinion always helps
Old Apr 10, 2007 | 08:50 PM
jjcsnlynn's Avatar
Where do I find the "Tire Calculator" ? I went from 235/16s to 255/16s. How much am I off, and what do I need to do to correct this?
Old Apr 10, 2007 | 08:59 PM
This thread is helpful if you're wanting to find out the width and height of your tires.
https://www.f150online.com/forums/sh...d.php?t=281530
BF Goodrich's website also has a tire calculator which will tell you the effects on speedo, gear ratio, ground clearance, rpms, etc. You will need to know your old and new tires' diameter though. I think the calculator is under their tips section. Hope this helps.
Old Apr 10, 2007 | 09:01 PM
ross2388's Avatar
Here ya go...
http://www.discounttire.com/dtcs/infoTireMath.dos
