12.50" tires
Old Mar 30, 2007 | 08:14 PM
nooq's Avatar
12.50" tires
will a 12.50" tire be any wider on a 10" wide wheel than a 9" wide wheel, or will the both setups be the same width?
Old Mar 30, 2007 | 08:51 PM
dondiesel444's Avatar
the tire will definatly be wider on the 10" wheel....
Old Mar 30, 2007 | 09:54 PM
nooq's Avatar
wandell?
Old Mar 30, 2007 | 10:32 PM
wandell's Avatar
Yeah, the tire will be stretched out an inch farther. Of course, the tread will be the same width. It will just appear larger because the sidewall is "buldged out".
Old Mar 30, 2007 | 10:38 PM
nooq's Avatar
when you say "buldged out" do you mean the sidewall will be sucked in more making the wheel look to wide for the tire? also, is there any problems that can occur running a 10" wide wheel with a 12.50" tire? odd wear etc...? is this a pretty common wheel and tire setup?
Old Mar 30, 2007 | 10:50 PM
wandell's Avatar
Most manufacturers recommend an 8 to 10 inch wide wheel for 12.50 inch wide tires, so either wheel will be fine.
When I say "buldged out", I mean the sidewall will appear very slightly more pulled outward on a 10 inch wide wheel. Honestly, I doubt you can notice a different between a 9 and 10 inch wide wheel.
