RABS Serious Issue
Old Mar 13, 2007 | 06:10 AM
JamesAtTECH's Avatar
RABS Serious Issue
Hey guys, need your help on this one!
I started up my '98 F-150 (140,000+ miles, good condition) when out of nowhere, my ABS light starts flashing. It flashed 16 times before cycling again. I cannot shift it out of park at all! I understand this model truck has RABS (rear anti-lock braking system), and if something were wrong, it may lock up the transmission and won't shift at all. I checked the fuse, and the fuse is burnt. When I replaced it with another fuse from another circuit, it blew immediately. Could be a short in the wiring. It just took me by surprise that it wouldn't shift into neutral with the accessory on.
It's at a dealership right now. Towing it was a bitch.
Side note...I was under the impression that ABS was developed in the late 80's-early 90's and that under normal driving conditions (no wet or snowy pavement) that it was fine to drive without ABS capabilities. If so, is there a way I can temporairly disconnect the RABS to shift the truck into neutral or drive?
Thanks.
Old Mar 13, 2007 | 08:18 AM
projectSHO89's Avatar
If it was F13 that was blowing, I'd say you didn't have your cruise recall performed and you have a shorted SCDS switch.
Your RABS is not the problem. The flashing light is simply due to the missing power feed (blown fuse). Also, your brake lights aren't working.....
Your "understanding" the RABS is quite mistaken. It cannot burn up the transmission.
Old Mar 13, 2007 | 12:04 PM
Yep! You are absolutely correct!
When I opened the hood yesterday, I smelled a burning (or smoldering) wire, but didn't know where it came from. I then noticed that a very small amount and fresh brake fluid was present on the brake feed on top of that switch. That was the recall item on the truck! I never did have it replaced.
Yep, it sure was the F13 fuse.
Damn, never thought of that. Thanks, bro!
Old Mar 13, 2007 | 03:21 PM
keith97xlt's Avatar
that cruise recall takes 10 mins at the dealer. dont want her to go up in flames.
