305/65R18 with 4.5" backspacing
Old Mar 6, 2007 | 11:08 PM
mcdaniqw's Avatar
I am wanting to put 305/65R18 BFG A/T tires on the Moto Metal 951s (w/ 4.5" backspacing). I have an '07 FX4 Screw with a 2.5" Autospring front lift.
Does anyone have pictures of a setup like this? Or does anyone know if I will have rubbing issues with this? Moto Metal also has a 6.18" backspace version and I wasn't sure if that would be a better choice?
I'd like for the tires to stick out an inch or so (if possible and not rub), and then I plan to add fender flares.
Old Mar 7, 2007 | 10:17 AM
scruz's Avatar
305's probably won't stick out past the fenders wells much. They're only 12" wide tires, so they should fit pretty flush with the wells.
I've been considering the 305/65/18 BFG's also, but I currently have 325/60/18 Nitto's, and I'm concerned about the BFG's being narrower and looking too small on the truck.
Old Mar 7, 2007 | 10:46 AM
WaWaTuSi's Avatar
they are 12.1 vs. the standard 12.5. I think your nittos are what 13.00?
I just picked up a set of the bfg's 305/65/18s mounted on an 18x9 pro-comp wheel with a 5" backspacing. I have the daystar 2.5 coil spacers. I'll post you some pics when I get em next week.
Old Mar 7, 2007 | 12:28 PM
wandell's Avatar
You are forgetting about the role of the wheel. A 9 inch wide wheel with 4.5 inches of backspacing will stick out 2.5 inches farther than the OEM 7.5 inch wide wheels with 5.5 inches of backspacing. A 9 inch wide wheel with 6.1 inches of backspacing will stick out about an inch farther than the OEM wheels.
Old Mar 7, 2007 | 05:12 PM
vipz's Avatar
I was thinking of going with the same setup...with the 4.5" backspacing. I just don't want them to stick out to far from the fenders. This may sound stupid but I was wondering if:
will a wheel that is 18x9 with 4.5 inches of backspacing with a 305/65-18 tire stick out from the fenders about the same distance as a 18x9 wheel with 5.5 inches of backspacing with a 325/60-18? If someone could answer this, I would be more than grateful.
Old Mar 7, 2007 | 05:38 PM
mccart125's Avatar
Wandell you are like a tire/wheel god..
Thanks for painting a picture for something I have trying to figure out forever..
Old Mar 7, 2007 | 07:56 PM
wandell's Avatar
Remember, the first number is the width of the tire in millimeters. So a 325 is 20mm wider than a 305. And only half of that (10mm) will be on the outside.
