Tire/Rim Combo question
Old Feb 28, 2007 | 05:44 PM
Meat12's Avatar
I have just put in an order for a set of 325/60/R18 Goodyear Silent Armor's
They come out to 33 x 13, the wheel I went with was the MM 951, 18x9 with 6.18 BS and +30mm offset.
1) Will they fit with a 2" leveling kit, Clearence/Rubbing?
2) How far will they stick out
According to my calculations I will be sticking out between 1 and 1.5" Please correct me if I am wrong.
Old Feb 28, 2007 | 06:03 PM
wandell's Avatar
Right, they should stick out about an inch farther than the OEM wheels. That combo will fit fine, if you have a 4x4.
Old Mar 3, 2007 | 09:17 PM
Meat12's Avatar
So with the above offset and backspacing on those wheels I will not have any rubbing on suspension components? I am just sitting here trying to figure out how the change in wheel and tire width will effect clearance issues with the suspension. I guess I just dont want to be stuck with rims that dont fit. Please ease my mind.
Old Mar 4, 2007 | 09:14 AM
wandell's Avatar
A few members here have similar combo's with no rubbing. The tire will be close to the upper ball joint but it shouldn't touch.
Old Mar 4, 2007 | 02:08 PM
Meat12's Avatar
Thanks, that area was my main concern as there is not that much room to spare with the stock setup. I am getting anxious, tires are in, but I am waiting for the wheels to get here as they are backordered.
Thanks again
Justin
