what you think 285/60/18
I have an 05 F150 4 x 4. if I get the Moto Metal 951 with the 4.5" backspacing on a 9" wheel. And run a 285/60/18 will I need to us a leveling kit? Does anyone have this size of tire on a similar wheel with a leveling kit? I have searched and I only found 1 set of pictures of this set up but could not tell if the tires looked too small or not due to the lighting.
If I were to level I only want to go with the 2". That is why I do not want to go with a 325/60 tire, it will probably run too much.
Please give me your input.
thank you,
thank you,
I am also going to go with the 2" AS leveling kit as I do tow and haul some heavy items, which makes the 2.5" to high. However, I plan on going with the MM 956 in an 18X9 with a 30mm offset. This is about 5.2" of backspace. I plan on using a 325/60/18 Nitto tire. From the research I have found this should not be a problem in terms of rubbing with a 04 - 07 4X4. I was originally looking at the 285/65/18 tire, but going for the larger tire for height and width. The large tire on this set up should stick out about 2" or so. Guys correct me if I am wrong with my statements. Cheers!!
https://www.rsracing.com/tech-wheel.html
30mm offset on a 9" wide wheel is around 6+" of backspacing. You really won't stick out much, if any, past the fender and should fit nicely.
Originally Posted by Mange
Dkstone: Why compromise? You're picking a small tire with a nice wheel just because of the backspacing. You can get the MM 951 in around 6" of backspacing and use a larger tire, up to the 325/60-18 if you want.
thanks
