bleeding brakes, preventative maint.??????
yah i know what you mean, but you also have to understand that as the brake pads wear down, the pistons on the calipers are pushed farther out, and there will appear to be less fluid in the system all together....
And another thing to think about too, is at 75 or 100k, it will probably be worth the effort to go ahead and replace all of the brake fluid, and not just bleed it
